tips to remove a 4x4 turbo !!
Old Oct 9, 2005 | 10:40 AM
rob w's Avatar
rob w
Default tips to remove a 4x4 turbo !!
right the turbo has spat its oil seals.
any suggestions to aid the removal will be greatly recieved.
Old Oct 10, 2005 | 10:24 PM
richm's Avatar
richm
remove the front compressor housing (held on with a ring of bolts from behind), you will then be able to get access to the 4 nuts holding the turbo to the manifold.
Old Oct 22, 2005 | 11:55 PM
moonstone4x4's Avatar
moonstone4x4
Dam! i didnt even think of that when i changed mine...took the manifold off instead!
Old Oct 23, 2005 | 01:02 AM
THE RADMAN's Avatar
THE RADMAN
still a couple of awkward buggers though,a bent spanner works a treat
Old Oct 23, 2005 | 09:28 AM
bud-weis's Avatar
bud-weis
Football Cwazy
wait for the engine to cool down
seriously though they are easy enough, just take your time and don't get rounding any nuts off!!
Old Oct 23, 2005 | 09:38 AM
Dave Henshall's Avatar
Dave Henshall
heres a quicky follow up then, i take it the actual seals are a servicable item then.... and the bearing..? if so where can u get them from for a std t34?
Old Oct 23, 2005 | 09:59 AM
richm's Avatar
richm
Stu?
Danny@RADesigns?
Otherwise Turbo Dynamics
Old Oct 23, 2005 | 10:05 AM
Dave Henshall
ill put a post up
Old Oct 24, 2005 | 07:50 AM
CosRush's Avatar
CosRush
Yeah i found that too.......
Old Nov 15, 2005 | 01:10 PM
Dave Henshall
another quicky... do u have to remove the turbo to replace the seals and bearings, or can it be donw in situ, just be taking teh downpipe and front cover off..?
Old Nov 15, 2005 | 01:35 PM
richm's Avatar
richm
another quicky... do u have to remove the turbo to replace the seals and bearings, or can it be donw in situ, just be taking the downpipe and front cover off..?
the benefit of having it on the bench would far outweigh the gain of avoiding taking it off the car..
Old Nov 15, 2005 | 01:39 PM
CosRush's Avatar
CosRush
Either way, i do hope you will take pictures and put it into the 'Technical Essays' section....
Old Nov 15, 2005 | 03:57 PM
Dave Henshall
will do indeed, im all set for saturday keep your eyes peeled
Old Nov 15, 2005 | 06:53 PM
Azrael's Avatar
Azrael
You need to rebalance it and all that after disassemply. So you can't just raplace seals on the car.
Old Nov 16, 2005 | 04:49 PM
Dave Henshall
but im going to be very carefull to mark up the orientation of all th parts in relation to each other sio that i can reassemble tham in the same way to avoid having to have it rebalanced,
much the same way, if u mark a tyre up where it fits in relations to the valve once its been balaned on the rim, you can remove the tyre and refit it in the same orientation and it is still balanced if u have it checked
the way i'm looking at it thoug, for 45 quid for the kit and a couple hours of my time, i'd much rather try it and see how it goes brfore spending 600 quid on a exchange turbo
2 days until teh write up
Old Nov 16, 2005 | 05:27 PM
CosRush's Avatar
CosRush
and counting.........
Old Nov 20, 2005 | 01:35 PM
Dave Henshall
all done,
will post teh pics up later in a tech essay.
bitter sweet though, turbo is done, found my battery drain, fixed the rear arm rest, but she still smokes and misses when she first starts, head is dead gutted
https://passionford.com/forum/viewto...726&highlight=
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
