Coilpack position....Interference???
Old Oct 6, 2005 | 09:32 AM
CosRush's Avatar
CosRush
Default Coilpack position....Interference???
Is there anything I need to know before mounting the coilpack in relation to other components and interference, such as the Ign amps, Map Sensor Ecu.........???
Old Oct 6, 2005 | 02:50 PM
Dave Henshall's Avatar
Dave Henshall
going on what ive hear before, not too near the map sensor, not near where water(rain) can get in and not too near the ecu, ideally where the coil was before like here on mine...
doest actually take up as much rom as you would thnk as its shorter than the original coil, albeit a bit wider. i mode a bit of an ally bracket to mount it using the original coil mounting studs.
Old Oct 6, 2005 | 03:25 PM
CosRush's Avatar
CosRush
Thanks for that, slightly different setup on mine, due to the car.........
My Ecu is behind the footwell panel, on the other side of the panel (2 inches) is the map sensor with Ign amp underneath that and the coil underneath that, altogether about 8" from top to bottom, so effectively coil and map sensor are about 6" apart........
Old Oct 6, 2005 | 05:08 PM
Dave Henshall
try it, it it runs ok then u may be ok, just going off what secs has said re the interferance the HT can cause with the map sensor and ecu.
bigluke200
14
Sep 2, 2015 10:35 PM
muz
Aug 16, 2015 12:57 PM
marky_g
Aug 15, 2015 10:43 AM
FAST AS FORD
Feb 23, 2006 05:52 AM
Cossie Sean
35
Dec 8, 2005 12:20 PM
