RS 500 inlet .... ???
Old Oct 4, 2005 | 11:12 AM
2wd's Avatar
2wd
Default RS 500 inlet .... ???
Hi I've got a question about a RS 500 inlet side, ... I know the plenum, elbow and throttle house is different, but I've been told that there is a difference in size on the inlet manifold where the injectors are placed...
I have never heard that (and I dont think it is), so does anyone in here know if it's correct that the RS 500 inlet manifold is bigger than the Sierra/Sapp and Escort inlet ???
Old Oct 4, 2005 | 12:47 PM
daz1968's Avatar
daz1968
I was led to believe manifold is same, but is dowelled to the head
Old Oct 6, 2005 | 09:04 AM
2wd's Avatar
2wd
I'm not quite sure I understand the last part...?
Old Oct 6, 2005 | 09:15 AM
DazC's Avatar
DazC
The plenum is wider but that won't have any effect on how the injectors or the fuel rail mount.
I don't think the manifold is dowelled either (has a pin in the head which located into a hol on the manifold to keep it in line when fitting).
Old Oct 6, 2005 | 09:47 AM
2wd's Avatar
2wd
Hmm..ok...but what about the size of the manifold itself (inside and out )...isnt it the same on a RS 500 and the other Cossies ???
Old Oct 6, 2005 | 11:58 AM
daz1968's Avatar
daz1968
In the manual it shows some small dowels in the head which I presume must have matching holes on the inlet manifold for location, but never actually seen one to know if holes are in std manifold or not, I believe internal trumpet sizes are the same, but if going for big power this would be ported anyway,
Old Oct 7, 2005 | 08:24 PM
PAUL S's Avatar
PAUL S
the trumpet section of the plenum is the same as all cosworths , on the 500 the inlet mouths closest to the head were opened up slightly by machining the casting thats all. Also as said there are two holes to fix a pair of dowels to.
So the answer to your question is yes they are all essentially the same and can be swapped about
Old Oct 9, 2005 | 02:06 PM
2wd's Avatar
2wd
ok and thanks..
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
