mf2 injector setup
Old Oct 1, 2005 | 08:36 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default mf2 injector setup
i am at the end of my zt build just had a look at mf2 controller looks nice bit of kit but would this run ok with my stalk 3i eeciv ecu or should i just go for ofab route just wondering about timing advance retard through ecu,of if it can b done okay looks alot simpler conversion.
any help,thanks tommy
Old Oct 1, 2005 | 10:12 PM
rsjohn's Avatar
rsjohn
mf2 controller runs seperate off its own pressure switch, well the one i had on my 1.9 S2 was. 5th injector kicked in at 15psi.
john
Old Oct 2, 2005 | 08:40 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
could i use this for all injectors obviosly when boost comes on more fuel in
the question i was ment o ask could i run this instead of changing ecu from xr3i 16v one,it says that it can run 4 injectors thinking cossie ones if this setup would work,thanks joh n
Old Oct 2, 2005 | 10:21 AM
rsjohn's Avatar
rsjohn
No i dont think so, best pming stu@msd or a tuner.
I thought with mf2 you can only run a 5th injector or water injection as continuous pulsing until pressure switch stops.
john
Old Oct 2, 2005 | 03:18 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
it says on there web site it will run 4 high imp injectors and 2 low imp injectors
Old Oct 2, 2005 | 07:19 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
or can i just run 1 big nice injector as a fith and blues on normal would this work with standard ecu
mk3ste
Oct 17, 2021 10:09 AM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
