idle control valve
Old Sep 30, 2005 | 08:53 PM
niceRST's Avatar
niceRST
Default idle control valve
just fitted a frst fuel rail and injectors to my zetec, problem is there is no space for the idle control valve, can i put this somewhere else and just blank off the additional holes.
Could i leave it off or will it cause probs,
anyone know????????????
cheers
Old Sep 30, 2005 | 08:58 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
i am at same bit on zt conversion m8 made up plates and stubs should work ok just mount on inner wing ,my girlfriend has 2i16v i disconected iscv and held up revs on throttle body didnt cause any probs so i may try that oc conversion just link up cable to manual choke think it should work
Old Oct 2, 2005 | 09:36 AM
richm's Avatar
richm
you can use a remote mounting block for the ISCV that is used on some EFi CVH cars - connects up with hoses..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
