Garret T3 pipes and hoses?????Help Please
Old Sep 29, 2005 | 06:48 PM
niceRST's Avatar
niceRST
Default Garret T3 pipes and hoses?????Help Please
I have bought a T3 turbo to go on my RS1800, trouble is im no mechanic and have no idea where any of the pipes and things are to go . Also whats the little thing inside the down pipe connector . Can and one help or maybe get me a diagram, anything,
thanks guys
Old Sep 29, 2005 | 10:10 PM
GrimmeRS2K's Avatar
GrimmeRS2K
little thing in the down pipe connector?, it isnt a lambda sensor is it with wires coming from it?
Old Sep 29, 2005 | 10:12 PM
niceRST's Avatar
niceRST
no, its a circular paddle, it has an arm connected to it through the casing
Old Sep 29, 2005 | 10:26 PM
GrimmeRS2K's Avatar
GrimmeRS2K
thats the wastegate mate, the actuator rod then connectors onto the arm
Old Sep 29, 2005 | 10:29 PM
niceRST's Avatar
niceRST
cheers, can i run a standard actuator or do i NEED a -31.
Its a 1800 zetec engine and a T3 garrett
Old Sep 29, 2005 | 10:31 PM
GrimmeRS2K's Avatar
GrimmeRS2K
depends on how much boost ur gonna run, over 14psi is best with a -31 i think
Old Sep 29, 2005 | 10:36 PM
niceRST's Avatar
niceRST
cheers, any ideas on the pipe work???????????
Old Sep 29, 2005 | 10:52 PM
GrimmeRS2K's Avatar
GrimmeRS2K
its pretty simple really, air in (inlet), which on efi will go to an induction kit etc
there will be a oil feed on the top
oil outlet pipe on the bottom
water inlet on top(if watercooled), water outlet underneath
small pipe from the actuator to bleedvalve etc
small pipe from compressor housing to bleedvalve etc
big pipe from the compressor to the intercooler
hope this helps, needs a diagram really
Cosnada
Jan 7, 2016 05:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
