replacing temp sender on 2wd saf
Old Sep 23, 2005 | 11:35 PM
rapidcossie's Avatar
rapidcossie
Default replacing temp sender on 2wd saf
not 100% sure my temp gauge reads right as it seems to sit just above the M and doesnt really move even when the cooling fans come on.
have bought a new one from ford but wanted some advice on fittng as the old one seems to be fitted with some kind of sealing paste?? (recently re fitted into my head after the rebuild)
can it be fitted with no sealer or maybe by using thread tape??
advice please?
Old Sep 24, 2005 | 12:22 AM
jon@work's Avatar
jon@work
fit it dry
Old Sep 24, 2005 | 01:19 AM
rapidcossie
will do!
Old Sep 26, 2005 | 10:20 AM
rapidcossie
going out to fit it now while im fitting my shiny new hoses!
any further input?
Old Sep 26, 2005 | 03:48 PM
rapidcossie
fitted the hoses and had a look at the temp sender...
its atucally the fitting that slides onto the sender itself that playing up i think as some of the wires are broken...
funny how it still works but i think it under reads...
now where will be able to get a new fitting? would prob be able and rejoin the wire if someone has an old loom lying around?
if not maybe one of the breakers??
Old Sep 27, 2005 | 02:46 PM
rapidcossie
done and dusted!
local scrappy had old granada, ripped the wire off that and changed sensor...
temp gaugenow beahving as it should
15
Oct 7, 2015 03:43 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
Ben26
Sep 3, 2015 07:55 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
