sensor help needed
Old Sep 23, 2005 | 11:48 AM
xrsi's Avatar
xrsi
Default sensor help needed
am after info on the threads of the following sensors to get adaptors to fit the cosworth sensors to the std positions in a cvh fiesta turbo
i need the info on the water temp sensors and the air charge temp sensors for both the cosworth and the fiesta turbo
thanks
Old Sep 23, 2005 | 05:47 PM
sammy's Avatar
sammy
My frst charge temp sensor had an adaptor on it, i removed it from the sensor & found it was the same thread as the water temp hole, my cossie water temp sensor then screwed straight in. with the iat sensor i got an old xr2i one, screwed it in, snapped off the sensor, then drilled & tapped it to suit the cossie thread.
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
