Oil Light......Tick, Tick, Tick.......WTF?!?!?!
Old Sep 22, 2005 | 08:25 PM
Big-J's Avatar
Big-J
Steer fi the rear!
Default Oil Light......Tick, Tick, Tick.......WTF?!?!?!
driving home tonight, my oil light comes on. i know theres oil in the engine as i only just checked it. it starts to tick, getting gradually louder and louder till its very loud.
any rough ideas of what the hells going on???
Old Sep 22, 2005 | 08:48 PM
sammy's Avatar
sammy
That is the sound of low/no oil pressure, its most likely to be a blocked oil pickup strainer, but it could be main bearings or oil pump too. have you recently done any work on it? used engine oil flush lately?
Get it sorted or it wont last long!
Old Sep 22, 2005 | 08:59 PM
Big-J's Avatar
Big-J
Steer fi the rear!
all i've done to it is fit an induction kit. i've only had the car for a fortnight :S prior to that i was told its been sitting for 2 months. i've hardly even driven it. how easy is it to fix?
Old Sep 22, 2005 | 10:20 PM
GrimmeRS2K's Avatar
GrimmeRS2K
deffo oil problem there, when mine done that it was that oil pump pick up pipe in the sump, but could be the pump itself
Old Sep 22, 2005 | 10:27 PM
Big-J's Avatar
Big-J
Steer fi the rear!
how easy is this to fix?
Old Sep 22, 2005 | 10:42 PM
GrimmeRS2K's Avatar
GrimmeRS2K
sump pick up isnt easy but not hard,
exhaust, starter off,cambelt off,bottom pully etc empty oil out, sump off
if you change the oil pump, you have to undo the engine mount bolt in the drivers side wheel arch to allow room to slide off oil pump
undo oil pump bolts off, undo the pick up pipe, allen key bolts, theres a gasket in between this could of just slipped out or maybe old and leaking, if is, that will be your problem.
Old Sep 22, 2005 | 10:52 PM
Big-J's Avatar
Big-J
Steer fi the rear!
cheers mate, i'll have a look tomorrow. fingers crossed its not done too much damage
Old Sep 23, 2005 | 09:09 AM
Damo V's Avatar
Damo V
the oil light is not a level indicator, its a pressure light... i imagine you have Łcuked your bottom end
Old Sep 23, 2005 | 09:54 AM
Big-J's Avatar
Big-J
Steer fi the rear!
its a tappety rattle. we've had a look and theres no oil getting to the head. oil pump me thinks...
Old Sep 23, 2005 | 12:08 PM
dox's Avatar
dox
oh dear, by the sounds of it, it does sound very good.
the tick may be main bearings, big or any other part of the engine
that doesnt get a supply of oil for that matter. personaly i wouldnt even start it
until ive had the sump off for inspection for how much damage was already
done.
Old Sep 23, 2005 | 02:47 PM
Big-J's Avatar
Big-J
Steer fi the rear!
oil pump failure. new one is on its way. just hoping nothing else is damaged. it was only run for about 2 miles while it was ticking. fingers crossed
Old Sep 24, 2005 | 04:25 AM
dox's Avatar
dox
swt just make sure you check all the bottom end for wear while its apart.
Old Sep 25, 2005 | 10:41 PM
GrimmeRS2K's Avatar
GrimmeRS2K
u should be ok, i ran mine for 5 mins with oil pissing out of the side of my pump.
Old Sep 25, 2005 | 11:39 PM
Big-J's Avatar
Big-J
Steer fi the rear!
find out tomorrow anyway when the new pump arrives
Old Sep 27, 2005 | 07:06 PM
Big-J's Avatar
Big-J
Steer fi the rear!
oil pump fitted. engine flushed. all is mint. well chuffed. phew
Old Sep 27, 2005 | 07:07 PM
Damo V's Avatar
Damo V
8 lives left for you mate well done
Old Sep 27, 2005 | 07:23 PM
Big-J's Avatar
Big-J
Steer fi the rear!
lol, fingers crossed from now on matey
Old Sep 27, 2005 | 10:41 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
