4x4 saphy problem!!!!!!!!!!!!!!
Old Sep 17, 2005 | 08:49 PM
jakki's Avatar
jakki
Default 4x4 saphy problem!!!!!!!!!!!!!!
ive just gone frm running 803's 2 putting light blues n a chip 2 run them in....but on first fire up and since then after putting them in when the cars cold its firing up then cutting out...once its warmed up a bit its revving between 500 n 1500 rpm.......once the cars 2 its normal running temp its running fine.....
now when the idle control valves disconnected its not surging like it does when the cars cold n its conected but the revs r that low when its diconected u couldnt run the car.
b4 putting the chip n light blues in it used 2 start up like it had a sensor off....it was over fueling but would sort itsself out....
any idea's what the problem is???? i cant c how putting a chip n differenet injectors in would cause the idle contro valve 2 pak up???
cheeRS
Old Sep 24, 2005 | 09:24 AM
Stu @ M Developments's Avatar
PassionFords Creator
The mixture and setup are totally wrong by the sound of things. Get her setup and checked over.
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
gcfcos
Sep 11, 2015 06:03 PM
routemaster
Sep 7, 2015 05:27 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
