hunting cossy
Old Sep 16, 2005 | 05:59 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default hunting cossy
hi
i have a saff cossy 4x4 and when its up to normal temp and youve just pulled up at lights etc the engine starts hunting between approx 500-1000 rpm. what could be causing this is it the throttle position sensor or idle control valve if it is one of these were are they located.
also whats the best gap to run your spark plugs at the old ones i took out were set at 0.27" and hand book says 0.40"
old plugs are denso new plugs are champion
thanks
mark
Old Sep 17, 2005 | 05:28 AM
dox's Avatar
dox
soundz like the idle control valve, its on the throttle body
Old Sep 18, 2005 | 11:17 AM
killerscum01's Avatar
killerscum01
Lose the Champions use motorcraft, plug gap 0.7mm, mixture sounds weak.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
