RS Turbo - very wierd problem
Old Sep 15, 2005 | 09:36 PM
revitt's Avatar
revitt
Default RS Turbo - very wierd problem
I've had my RST a few days now, its had a brande new engine by power engineering and usually ticks over perfect, but occasionally it seems to run very lumpy, when either cold or hot, barely ticking over at 500rpm or less, about to stall. then all of a sudden it will just sort itself out and run perfect again.
Also on two occasions ive gone to start it, the starter motor has been turning over at the usual speed with a fully charged battery, but the car refuses to even try to start, doesnt fire at all. then if you bump it off, drive the car for a moment, turn it off and try to start it again it fires up straight away!
Last but not least, tonight while driving in the dark the temp gauge started to rise as ususal as the car warmed up, but then started to fall again, the headlights and dashboard seemed to get more and more dull until i had to pull over, i turned the car round and headed home. gave it a good bootfull and suddenly the lights brigthened back up and the temp guage shot instantly to Normal!!??
Im totally confused by these problems and dont know if theyre connected in any way, but any suggestions would be greatly appreciated
cheers,
James
Old Sep 15, 2005 | 10:14 PM
GrimmeRS2K's Avatar
GrimmeRS2K
tick over could be a possable air leak somewhere around the breathers, or a dumpvalve problem (if u run one)
the other problem could be a dodgy alternator, connections or the belt a bit slack, also check the termanals on the battery are nice and clean and tight
Old Sep 15, 2005 | 11:35 PM
cul's Avatar
cul
welcome to the troubles of the ford rs
Old Sep 15, 2005 | 11:36 PM
cul's Avatar
cul
definately dodgy alternator or loose belt causing the power to go ........
Old Sep 16, 2005 | 09:05 AM
mart.rs's Avatar
mart.rs
yeah definitly a air leak,check all ya pipes for tightness etc....
Old Sep 16, 2005 | 05:36 PM
revitt's Avatar
revitt
ok cheers, altenator seems to be quite new but wire going from altenator to the battery seems to be coroded. will replace that and see what happens.
thanks everyone
Old Sep 16, 2005 | 06:25 PM
GrimmeRS2K's Avatar
GrimmeRS2K
thanks everyone
that should solve your problem, hope u get it sorted
Matt Baxter
Sep 16, 2015 08:30 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
