whinning turbo
Old Sep 15, 2005 | 06:22 PM
simhopper's Avatar
simhopper
Default whinning turbo
when the throttle is opened the turbo/manifold whines like f**k
thought it was either a blown gasket or a cracked manifold
had both off replaced the gaskets and had the manifold checked for cracks which came back negative
i did have the turbo(gt2560) stripped down and there is no play in the shaft it had to be stripped down to be cleaned as the machine shop had to helicoil a thread and didnt seal the ends
what i did notice is that the compressor side of the turbo was covered in grease and this was cleaned and removed but wasnt replaced..........could it be the scrapping of metal to metal thats causing the whine????
think its time for a recon or new turbo
Old Sep 15, 2005 | 10:04 PM
cossiegreg1's Avatar
cossiegreg1
will your car not even boost?mine whined like fuk and wouldnt go past 0psi and im afraid i had to replace the turbo.my shaft had quite a bit play in it tho
Old Sep 15, 2005 | 10:13 PM
simhopper's Avatar
simhopper
it does come onto boost but only slightly
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
