zetec help needed
Old Sep 13, 2005 | 06:28 PM
rwd106's Avatar
rwd106
Default zetec help needed
im just buying me up a few bits to build a zetec engine and get rid of my cvh 1.6 turbo.
i had bought cossie management to fit to the cvh but decided not to bother as for the power id get from it i may aswell spend a bit more and get me a zetec and allow for more power and torque.
ive read i can use mt cvh zaust manifold and probably my turbo its a pd28 or summat like that i cant remember but held 20psi boost and spool up was quick enuff. its a hybrid turbo anyway and will do for a start!
wats the best inlet manifold to use? ive got efi from fiesta turbo as was gona use this with cossie management, ive read that some some people use a rover turbo manifold? any views on wats best. ideally i want 300bhp+ and dont know if one is best suited to that sort of power?
ive got dark blue 4x4 cossie injectors. r these up to the job?
and also do i need the cossie managment now, i got stg3 chips, l6 ecu, loom, 3bar map sensor and all manner of other cossie bits i needed...... or...... do i use zetec management, is this mappable or easier to use?
all advice would be great
thanks
adam
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
col93saphcos
Aug 7, 2015 03:21 PM
