zvh question
zvh question
what would happen if i used the standard pistons with this conversion.
basically putting the head on the bottom end and not lowering the compression at all???
have a little search around mate, been covered loads of times
check out this site its very informative
http://www.quantums.info/zvh.htm
allegedly the standard zetec pistons are good for up to 1 bar, plenty of people have used them... skimmed, unskimmed, spacer plate etc. but as with any non forged piston in a turbo engine its always a bit of a risk.
so in that case so it is alright to use standard pistons unskimmed and NO decom plate either???
the pistons a from a 94 mondeo so they are the stronger ones..
12PSI is all i want to run .....
