frst chip question
Old Sep 9, 2005 | 06:58 PM
chubbs358's Avatar
chubbs358
Default frst chip question
just looking for some advice. i want to spend some cash on my frst but just want to see if im thinkin of spending it in the right places
I was planing to get stage 2 chip, beige injectors, cam set(dont know what one?) and head gasket whould this be wise without a bottom end rebuild? also any other advice or ideas would be apreciated very much
thanks
Mark
Old Sep 11, 2005 | 11:44 AM
chubbs358's Avatar
chubbs358
bttt
Old Sep 11, 2005 | 12:37 PM
sammy's Avatar
sammy
An engine rebuild is always ideal, but as long as it's healthy it should be ok, the stage 2 chip, injectors & an uprated actuator is a good option, they do recommend an uprated fuel pump too. as for the cam ive allways used piper 285 t2, but ive heard they can wear out quick (personally think they havn't been insalled/run in propperly) so the kent version may be worth a look at, a vernia pulley is best fitted to set the cam up. why are you replacing the head gasket? also start saving for a new turbo, the weak T2 turbo dont last long on high boost, hence lots going to the cheaper stronger T3.
Old Sep 11, 2005 | 01:00 PM
chubbs358's Avatar
chubbs358
well im not shure yet if the slight oil leak is on head gasket or cam seal so i might not need to do it depending what i find. will the car need setup after chip and cams are fitted or should it run fine as it is
thanks
mark
Old Sep 13, 2005 | 06:14 AM
sammy's Avatar
sammy
a set up is always a good thing & i would do so, but its not required.
Old Sep 13, 2005 | 01:38 PM
chubbs358's Avatar
chubbs358
yea i would get it done but because of where i live i might not beable to get it done right away and didnt know if it would be wise to run it without geting set up proply
thanks
mark
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
A.t.p
Sep 29, 2015 05:04 PM
