referbing and spraying wheels
Old Sep 8, 2005 | 11:07 PM
wardyxr2's Avatar
wardyxr2
Default referbing and spraying wheels
i want to referb and spray some pepperpots for the winter.
i want to have a gloss balck centre with a silver rim.
whats the best way to do this DIY style?
what will i need to do it?
and roughtly how long would it take?
cheers
Old Sep 8, 2005 | 11:20 PM
antony215's Avatar
antony215
Escort Rs Turbo
Rub it down primer the hole wheel then spray the center first let it dry then mask it up then spray the rim silver let it dry then lacker the wheel
YOU NEED masking tape/primer / sand papper / gloss black paint / silver paint /clear lacker probley take a good few hours to do
Old Sep 9, 2005 | 01:13 PM
Al Bags's Avatar
Al Bags
Makes it sound easy, doesn't he!?
Didn't mention that they should be thoroughly degreased, all old loose paint/lacquer removed ... and putting on lacquer is tricky .. loads of thin coats.
It runs so damn easy.
Old Sep 9, 2005 | 02:04 PM
antony215's Avatar
antony215
Escort Rs Turbo
I would think that would be obvious to degrease them first
It is easy if you know what your doing if you don't then that makes it hard job to do
Old Sep 9, 2005 | 03:58 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I remember reading somewhere that you shouldn't put any paint where the wheel nuts meet the rim to make sure they don't undo themselves when driving.
Not sure how much of it is true, it kinda makes sense, but I would have thought the paint would peel off quite quickly when the nuts are done/undone.
Not sure if this helps, but it could
Old Sep 9, 2005 | 05:21 PM
Al Bags's Avatar
Al Bags
Yep .. correct .. no paint on the seats.
... and Anthony ... You'd be surprised at how many do them with the old silver wheels stuff, after a quick rub down, mate.
I have been working on cars for 30 years ish .. and it ain't easy to do them properly.
Old Sep 9, 2005 | 05:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
[quote="Al Bags"]
Your right there alot of people do just spray over the old paint in a rush to get them back on the car and it don't take long before it starts to come off so if your going to do it do it properly or they will look sh*t if you rush the job
Old Sep 9, 2005 | 06:42 PM
monkey24's Avatar
monkey24
And dont forget to take the masking tape of before you lacquer them
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
