Rev Counter pointing at my ABS light!!!!!!
Old Jul 1, 2004 | 07:48 AM
kjc300's Avatar
kjc300
Default Rev Counter pointing at my ABS light!!!!!!
Cossie didn't start first time yesterday, started second go. Done it again later on and then I noticed that my rev counter needle was pointing at my ABS light!!!! I definetely haven't been anywhere near 10,000 rpm!!!!
It's now skipped round to behind the needle stop!!!!
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pppplllllllllllleeeeeeeeeaaaaaaassssssse!!!???
Old Jul 1, 2004 | 08:15 AM
kjc300's Avatar
kjc300
Old Jul 1, 2004 | 12:29 PM
garaged2000's Avatar
garaged2000
hiya,
just as a suggestion as i had speedo needle play silly with me before and it came down the physical worm gear in the rear of the dash, so after opening the back of the dash up and prodding it was fine. If the needle doesnt move atall (10k or behind the stop it sounds like a physical thing as opposed to the electrics side of thing. But not sure if it may be that simple as the rev' works as a volt meter it may be getting to much power from an unknown source.
Not sure if this is any help, but best of luck.
Old Jul 1, 2004 | 05:06 PM
kjc300's Avatar
kjc300
bttt
Old Jul 1, 2004 | 06:44 PM
kjc300's Avatar
kjc300
Old Jul 1, 2004 | 09:30 PM
kjc300's Avatar
kjc300
it's still there, on the wrong side of the stop!!! It's gone right round!!
Old Jul 2, 2004 | 02:29 PM
EscortCosworthUSA's Avatar
EscortCosworthUSA
If you pull out the trip reset and get a small wire you can just push it back over - done this on mine a couple of times.
Old Jul 5, 2004 | 06:56 PM
kjc300's Avatar
kjc300
Cheers mate, all sorted - done it with a cable tie!!!!!
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
cozzzzy power
Sep 4, 2015 08:14 AM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
