4x4 Saff Cossie starting problem..HELP please
Old Sep 8, 2005 | 07:24 AM
K&J Motors's Avatar
K&J Motors
Default 4x4 Saff Cossie starting problem..HELP please
Morning gents, Hopefully someone can help with my 4x4 Saff that won't start.
It was starting and running fine, parked it one evening, next morning it turned over and over without starting, the fuel pump was running but didn't do its usual whhirr then stop as it pressured the system, it was just turning lightly, I have just changed the fuel pump, it sounds marginally different now but still won't start. Do you need to 'bleed' the fuel system to remove air after this type of job or does it self prime?
Is the fuel pump polarity conscious? It had no markings on either so have assumed not?
The only thing other than that I have done since it last ran was remove some old amp and speaker wiring, nothing was connected and don't believe I have desturbed anything during removal.
Any advise or ideas would be most welcome, I am not a mechanic and usually put it in a garage for any work but need to get it running to do that
Regards
Jeff
Old Sep 8, 2005 | 05:29 PM
cossiegreg1's Avatar
cossiegreg1
alright matey,Are you absolutly sure you havnt disturbed any wires or flicked any switches just cos you may of disturbed the immobiliser,if one is fitted?also ev1 hides kill switches in cossies in stupid places so make sure you havnt accidently knocked 1.i know this sounds stupid but try wiggling the battery leads,coil lead plug leads etc.it may be a bad connection somewhere,its worth a try!! let me know how you get on... thanx greg
Old Sep 8, 2005 | 06:45 PM
koopza's Avatar
koopza
fuel pumps do need the correct polarity or they will spin other way. best idea is to find someone with a star tester tech tool, most likely crank angle sensor if so you will not have spark .
Old Sep 8, 2005 | 09:05 PM
K&J Motors's Avatar
K&J Motors
Thanks for taking the time to reply gents, the fault was traced to 2 loose multi-plugs which must have been disturbed under the engine bay removing one of the power leads for the amps, we are rocking again
Thanks again
Jeff
cossie330
Aug 22, 2015 12:00 PM
Anutternutter
Aug 21, 2015 06:07 PM
mrmann
Aug 20, 2015 11:24 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
