Early saph dash into a 3door
Old Sep 24, 2003 | 10:45 PM
SteveW's Avatar
SteveW
Default Early saph dash into a 3door
are all the mounting points the same, basiclly will it fit. the cracks in my dash has got alot worse this year at the shows due to the heat.
cheers
Steve
Old Sep 25, 2003 | 08:07 PM
RobCarden's Avatar
RobCarden
358bhp
this prob won't help but...
ive got the same prob. ive also got an early saff dash with out the vent in the middle at the top. this might be going in my 3 door, not tried to fit it yet. if it would help i can post pics of the rear of the saff dash??
Old Sep 25, 2003 | 10:04 PM
SteveW's Avatar
SteveW
cheers Rob, pics would'nt really help at this stage as i have not taken the original 1 out and dont know where the mounting point are, cheers though. if u do yours let me know how you get on.
cheers
Steve
Old Sep 27, 2003 | 02:39 PM
chRiS & dawn's Avatar
chRiS & dawn
I once put an early saph dash into an XR4i which i presume will have the same mounting points as a 3dr.
All the main mounting points were in the same place but i was just using the top half of a saph dash and fitting all the vents, switches, dials,etc from the 4i to try and keep it as original as possible.
I got it all in in the end but took a bit of time to get it to look right but once in looked ok.
I used the original lower half of dash and this fits ok but there were differences around steering column area with one or two gaps.
You will probably need the A pillar trims from a saph aswell as they are different at the bottom where its meets the dash top.
From what i remember the curve of the saph dash is slightly different along the windscreen but isn't noticable once in.
It was a few years ago so might have missed something.
Chris
Old Sep 27, 2003 | 05:20 PM
swerv's Avatar
swerv
it will fit i know a few people who have done this
Old Oct 1, 2003 | 09:34 PM
SteveW's Avatar
SteveW
cheers, it is just the top half i want to change.
cheers again
Old Nov 9, 2003 | 06:16 PM
XR4Timan's Avatar
XR4Timan
Any Sierra dash will fit any Sierra - no modicfications needed. Just keep in mind you will need the A-pillar trim as well.
Old Nov 9, 2003 | 06:21 PM
XR4Timan's Avatar
XR4Timan
Here take a look at this pic:
You'll notice the Sapph dash (actually a late Merkur - same thing) installed on my 3 door. Notice the gaps at the ends where the A-pillars join. That's why you need to also get the early Sapph A-pillar trims which fill in these gaps. One thing to note is that the screwholes in the Mark 2 A-trim don't match, so you'll need to drill new ones or better yet, use double stick tape and place them in place.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Fordmad!
Sep 29, 2015 07:03 PM
Russ Payne
Sep 25, 2015 08:29 PM
