abs
abs is doing my head in the light stays on ive had the sensors checked all ok but its still on
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
check your fluid levels too,s2s lights come on early!
maybe best to check your brakes proper,spraying wd40 may contaminate your pads,and cause slippage
after all,they stop your car!
have a look at the the casing where the two sensors sit(one at the front and one at the back, all you gotta do to make the light go out is to get the sensor and hold the clip in then just put some tape around it to stop it from not touching,do the same with the other one and bob your uncle! od you could do what ive done and just diconnect the whole lot because it dont work anyway as any modded s2 ownwer will tell you, get an xr3i master cylinder,then just remove the remaining pipes!!
