anyone with a quickshift
Old Nov 20, 2003 | 02:16 PM
sm's Avatar
sm
Default anyone with a quickshift
hi
i just got a quickshift for my s2, i noticed that the original ford assembly had 2 big rubber bits on the part which bolts to the floor pan, i take it this is to stop it rattling and vibrating, my quickshift is just a block of ally with 4 fixing bolts, it rattels a bit on start up and also when the clutch is at biting point, it shifts perfect, just this rattle is really annoying
Old Nov 20, 2003 | 02:42 PM
cossymad's Avatar
cossymad
Stupid question...is it done up tight enough? It sounds like you have a b&m one and if this is the case I've sold loads of them and never had a problem.
Old Nov 20, 2003 | 02:59 PM
sm's Avatar
sm
its a b&m one, its as tight as i can get it but it creaks when the clutch is at biting point, might make a gasket out of rubber and try that
cheers sm
anyone else had this problem?
Old Nov 21, 2003 | 03:20 PM
sm's Avatar
sm
right, ive made a gasket and now it dosent rattle or vibrate but when i come off the throttle (whilst in gear) it seems noisier than my old one
any help appricated, cheers sm
Old Nov 21, 2003 | 04:04 PM
cossymad's Avatar
cossymad
mate I am baffled I'll have a word with a few other people and I'll get back to you.
Old Nov 21, 2003 | 04:12 PM
sm's Avatar
sm
cheers, its a 2nd hand one, was bought 6 months ago and was only used for 1 month, the bloke also said the linkage was 6 months old too, anyone got some fitting intstructions they could send or email me? and ill fit it to my original linkage and see if its any better
cheers sm
Old Nov 21, 2003 | 04:15 PM
cossymad's Avatar
cossymad
I'll get you some instructions for Monday if you want.
davie0146's Avatar
davie0146
mate i got a burton one with the complete linkage etc
looks like a straight fit to me but good luck
Old Nov 21, 2003 | 04:17 PM
sm's Avatar
sm
cossymad, cheers for that, ill look on the web aswell, someone must of fitted one before and posted how to do it
just noticed that if u drive along and dip the clutch whilst in gear the noise isnt as loud as it is when ur cruising along with the clutch up, if u take it out of gear u get no noise
cheers sm
sm
Aug 1, 2006 05:57 PM
G2 FSR
May 11, 2006 06:44 PM
Lincolndanny
Apr 7, 2006 07:04 PM
STEPHEN1921
22
Mar 2, 2006 04:41 PM
Rippers
Oct 13, 2005 08:24 PM
