cams??
Old Aug 28, 2005 | 12:24 PM
dips346's Avatar
dips346
Default cams??
hi need to know i have a 4x4 saff and want to know with standern new oversized 0.5 bore pistons will be fine with a bd 10 exhaust and a bd 14 inlet ,a friend doing the job says he has done this before and its fine but a few people have said the valves will hit please help..thanks
Old Aug 28, 2005 | 04:03 PM
rsjohn's Avatar
rsjohn
You have to have cut outs on the pistons to run BD14 cams, BD10s are fine.
john
Old Aug 28, 2005 | 04:09 PM
dips346's Avatar
dips346
SEE THATS WHAT I HAVE BEEN TOLD BY A FEW PEOPLE BUT THE GUY THAT REBUILT MY MATES ONE STILL SAY YOU CAN USE STANDERN PISTONS,MY MATE HAS HAD NO PROBLEMS AND HE IS RUNNING 380 BHP ISH.......STILL LOST
Old Aug 28, 2005 | 04:12 PM
rsjohn's Avatar
rsjohn
I have had 2 engines running BD14s and both had valve cut outs.
I was told you can run standard pistons but have to advance the cam timing!!!
Whats spec of your engine??
john
Old Aug 28, 2005 | 04:43 PM
dips346's Avatar
dips346
spec not much full rebuild ,head ported and polished,as above new pistons,greys,rs500 intercooler,air to air,normal other things map,catch tanks,and so on and a hugh £2000 turbo the guy goes as long as the bd14 is fitted and timed at tdc the valves will not hit
Old Aug 28, 2005 | 07:21 PM
Chris Honeywell's Avatar
Chris Honeywell
I had a BD14 inlet on standard pistons
everything was fine has to be timed up spot on though
Old Aug 28, 2005 | 09:05 PM
rsjohn's Avatar
rsjohn
Not worth the risk though is it!!!!
You could get valve bounce at high rpm which could make valves hit pistions.
john
Old Aug 29, 2005 | 06:56 PM
Chris Honeywell
john
not if you have double valve springs m8
and standard rev limit aint high really
I can't see you will have any problems
Old Aug 29, 2005 | 10:23 PM
rsjohn's Avatar
rsjohn
john
Why have you not got standard pistons then????
john
Old Aug 29, 2005 | 10:33 PM
dips346's Avatar
dips346
thats what i was told to buy ,thats why i am stuck now as he has rebuilt the engine now ,so its either put normal cams back or take out the pistons
but i was thinking if the cams worked (bd14) i might get away with it
Old Aug 30, 2005 | 06:51 PM
rsjohn's Avatar
rsjohn
If it was me and id spent the money on what you have already bought i would go BD10 route.
john
Old Aug 30, 2005 | 06:58 PM
dips346's Avatar
dips346
what will i lose out on if i put bd10s and not the bd 14
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
