No oil!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 24, 2005 | 07:12 PM
cul's Avatar
cul
Default No oil!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i checked the oil level today and found that my car had burned every last drop of oil out of it in about 2 weeks.
what the f*c* could be causing this.
is is possible that my turbo seal is gone on the exhaust side and its leaking oil straight out the exhaust and burning it????
No oil in boost pipes and no smoke when i come off boost.
Only smokes when the car is being reved at idle and when accelerating.
and i have a compression of 10bar from each cylinder.
for the love of god help me before i do something stupid like selling it
Old Aug 24, 2005 | 10:07 PM
16vzetec's Avatar
16vzetec
valve stem oil seals????
Old Aug 24, 2005 | 11:45 PM
cul's Avatar
cul
valve seals are new and even if they were fucked they wouldnt drain a sump in 2 weeks.
Old Aug 25, 2005 | 05:32 PM
rssapphowner's Avatar
rssapphowner
valve guides mate
Old Aug 25, 2005 | 05:44 PM
Al Bags's Avatar
Al Bags
I tend to think it's the turbo, too.
If it's the stem seals, you usually get the oil burnt off after lifting off then planting it again .. The depression in inlet is sucking it in, then burning it out when you put your fut down again. You can test that to a certain degree.
Old Aug 25, 2005 | 08:35 PM
rssapphowner
i have similar prob with mine when i back off then put foot down it smokes like a bitch is it seals or turbo?
Old Aug 25, 2005 | 09:21 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Stu once said that this was due to the lack of exhaust pressure letting particles drop in the exhaust, until you give it a boot full which has the same effect as sweeping a 20 year old chimney
Old Aug 25, 2005 | 09:25 PM
rssapphowner
how do i cure this re seat valves?
Old Aug 25, 2005 | 09:26 PM
rssapphowner
the turbo is 6 months old and pulls no probs no white smoke on start up
im pulling me hair out
Old Aug 26, 2005 | 08:45 AM
Dave Henshall's Avatar
Dave Henshall
whas does the yellow sticker say on th cam belt cover from new....... "check oil daily"
there is a reason for this...
Old Aug 26, 2005 | 03:55 PM
frog's Avatar
frog
It's a FORD, so its needs "Filling with Oil Regularly even Daily"
Old Aug 26, 2005 | 05:30 PM
rssapphowner
i do fill oil but dont a tanker to follow me pmsl
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
