4x4 ESCORT COSWORTH WATER PUMP
Old 22-08-2005 | 07:16 PM
fordrallycar's Avatar
fordrallycar
Default 4x4 ESCORT COSWORTH WATER PUMP
HI ALL
ANY EVER FITTED A WATER PUMP TO ESCORT COSWORTH SMALL TURBO IS THERE MUCH INVOLVED & COULD YOU EXPLAIN HOW TO CHANGE IT
ANY HELP WOULD BE MUCH APPRECATED
CHEERS PAUL
Old 22-08-2005 | 07:37 PM
Dave McB's Avatar
Dave McB
I assume its the same as the 4x4 saf etc
1. loosen 4 bolts on water pump pulley
2. remove both alternator belts
3. take pulley off
4 loosen all bolts and hoses, drain water system and remove pump
5. put new pump on using appropriate gasket and a very small amount of gasket seal
6 do steps 4, 3 2 then 1 in reverse
7 fill cooling system
Vincereese
01-06-2023 09:14 AM
jessie_rs
11
03-06-2019 04:57 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: 4x4 ESCORT COSWORTH WATER PUMP
