S1 turbo running probs
Old Aug 22, 2005 | 01:56 PM
spitfire_bob's Avatar
spitfire_bob
Default S1 turbo running probs
Hi,can anyone out there please help!!!!!
I have an S1 turbo which has the following intermittent fault;
when going along( no matter what speed) engine will stutter/hesitate,rev counter will drop then shoot back up again & sometimes will backfire leaving cloud of smoke?????
Can it be fuel related such as blocked filter/tank?
Have changed coil & leads but still the same
Bob
Old Aug 22, 2005 | 10:15 PM
johnnysash's Avatar
johnnysash
with the rev counter dropping sounds more like an electrical fault than fuel...especially with the backfire. maybe a fault on the dizzy/low tension side of things as the rev counter is dropping....try wiggling /touching the low tension wires to the coil and dizzy when the engine is running to try and make the fault happen again....then remeber what wires you touched and look towards changing them.
also check all the contacts/connectors of wires for any of the green mank/corrosion that has a habbit of growing
good luck.
Old Aug 22, 2005 | 10:22 PM
RS2000_Daz's Avatar
RS2000_Daz
I would check your ignition wiring (especially where the connector block is) as well they have a habit of corroding
as said above really
Old Aug 26, 2005 | 12:44 PM
spitfire_bob
right will try those today!Fingers crossed
Old Aug 26, 2005 | 12:55 PM
GrimmeRS2K's Avatar
GrimmeRS2K
sounds like the dizzy fooked
Old Aug 26, 2005 | 01:02 PM
rs_daz's Avatar
rs_daz
I had the same sort of problem on my s2..backfiring rev counter droping not starting etc...try a new distributor or buy the hall sensor thats inside about £40
Old Aug 27, 2005 | 05:03 PM
spitfire_bob
Finally cracked it!!
After changing dizzy cap,rotor arm,plugs,coil,dizzy
A wire on the connection to amal valve was bared & was touching a braided water hose which in turn was shorting out acroos the braided oil feed to turbo ( so much so that in put a hole in oil feed mmmmmm not too much oil pi***d out!!!)
Running like a dream again
Thanks for your replies guys
regards
Bob
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
ray barker
Aug 7, 2015 09:00 AM
