TPS sensor
Old Nov 18, 2003 | 03:07 PM
Toe Knee's Avatar
Toe Knee
Default TPS sensor
Should it be mounted so its striaght on the throttle body housing or at a slight angle?! notices you can angle it slightly which would open the butterfly slightly.
CheeRS
Old Nov 18, 2003 | 07:01 PM
Toe Knee's Avatar
Toe Knee
Someone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 18, 2003 | 10:46 PM
Stu @ M Developments's Avatar
PassionFords Creator
It needs to be set with a multimeter ideally.
Old Nov 18, 2003 | 10:55 PM
Toe Knee's Avatar
Toe Knee
Cheers stu, just wanted to make sure it wouldnt cause any probs before i take it to a tuners!!! Will get a new chip and set up done as soon as she runs
Old Nov 19, 2003 | 09:00 AM
foreigneRS's Avatar
foreigneRS
Testing the future
don't use the tps to open the throttle butterfly! you will put too much force on to it working against the throttle closing spring and will damage it.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
