Got a weird grinding noise...
Old Aug 1, 2005 | 08:44 PM
EvilFranky's Avatar
EvilFranky
Default Got a weird grinding noise...
Can hear it especially in 1st and a bit in 2nd gear. If i give it a bit of stick in first you can hear it aswell...almost sounds a bit like induction roar, but goes away once you change into the higher gears.
I can make it happen by slowly lifting the clutch pedal.
Engine still running fine so i've ruled out another engine rebuild LOL.
Anyone give me any ideas? Got me a bit stumped
Old Aug 1, 2005 | 09:17 PM
boost mad's Avatar
boost mad
u say it happens when u lift the clutch pedal slowly.... is that in and out of gear? if so it maybe your clutch/thrust bearing mate. not to expensive bout £10 but it means gearbox off
Old Aug 2, 2005 | 06:28 PM
EvilFranky's Avatar
EvilFranky
Yeah mate, does seem to be in and out of gear.
I'll see about getting the box off when i'm next off work and having a look.
Old Aug 3, 2005 | 05:24 PM
danxr2i's Avatar
danxr2i
i had the same noise in 1st and 2nd on my xr2i, the gearbox was worn out.
Old Aug 4, 2005 | 06:43 AM
EvilFranky's Avatar
EvilFranky
To be honest mate i wouldnt be surprised.
Its 88k standard box thats seen some abuse in the 4 year i've owned the car...going to look out for a gearbox now aswell.
paceo
Feb 3, 2016 10:31 AM
20/20 vision
Sep 29, 2015 09:25 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Sheepdisease
Aug 30, 2015 09:11 PM
TrevCos
Aug 17, 2015 09:08 PM
