fuel pressure regulator
Old Aug 1, 2005 | 11:42 AM
Matt_rS's Avatar
Matt_rS
Default fuel pressure regulator
Any body have any idea why my s2 88 rs has trouble starting an will not rev up with the pressure reg connected, it idles fine without it but as soon as a i connect it up it cuts out,try revving it an it misses.Clearly overfueling!Any suggestions would be much appreciated!have changed metering unit & fuel pump,the fuel ecu work on my mates so where do i go next? As i say any help will be much appreciated!
Cheers Matt
oh the car starts fine when warm without it connected but not when cold.
Old Aug 1, 2005 | 12:58 PM
GrimmeRS2K's Avatar
GrimmeRS2K
theres a fuse in the fuse box for heated seats, this is for the fuel ecu, check its not blown
timsrs
Nov 13, 2018 11:48 AM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
