Suspension problem Mk3 3i
Old Jul 31, 2005 | 04:12 PM
Anthony B's Avatar
Anthony B
Default Suspension problem Mk3 3i
Hello all
Got a problem on my 1983 XR3i which I have been restoring and is now getting pretty well sorted.
One problem I have never fully sorted is a clonk from the NSF wheel. Last year, about 1000 miles ago, I changed the lower arms and anti roll bar bushes, the front wheel bearings and the shock absorbers due to this clonk from the front..I genuinely thought it was the wheel bearing.
Anyway, the above has not sorted the problem and it still knocks on heavy bumps, OK on small ones.
The only thing I can think of now is either the top mounts (two bolt type) or the spring is weak. The car passed it's MOT no problems.
Also, I'm thinking it may be the front engine mount as there is a big gap between the lower cup and the rubber part....is this normal?
Anyone else had this or any ideas please.
Many thanks
Ant
Old Aug 1, 2005 | 07:47 AM
mart.rs's Avatar
mart.rs
ill think you will find its the cv joint,it will click and knock as you go round corners and over bumps and maybe on full lock too! definitly sound s like it!
155lee
Sep 6, 2016 11:10 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Bighandsuk
Sep 2, 2015 05:23 PM
