2WD Cooloing System
Old Jun 24, 2004 | 07:57 AM
C0S_TURBO's Avatar
C0S_TURBO
Default 2WD Cooloing System
I have a 2wd Saph and I have noticed that the water in the cooling system is a brown colour. What is the best way to flush and refill the cooling system, any additives to prevent it happening again?
Many thanks
Old Jun 24, 2004 | 01:02 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
take bottom hose off of radiator and let it drain then put hose pipe in header tank and let run.
Never tried it but it might work. or you could drain the system and then refill it and start the car and then drain it again.
Old Jun 24, 2004 | 03:45 PM
wes's Avatar
wes
Brown water means rust! The block is cast iron and no antifreeze means it will rust, and the alloy head will corrode, not good!
Remove header tank cap. There is a bolt in the block on the exhaust side near the rear of the engine (17 or 19mm i forget now). You remove this to drain the block of coolant. Then remove the bottom hose of the rad to drain that. Remove the top hose and remove the thermostat (buy a new one when you buy your ANTIFREEZE!) and then use a hose pipe in the end of the housing to flush the old crap out of the drain hole (until it comes out clear). Then replace the bolt in the block. Then put the hose in the bottom rad outlet and flush it until clear water comes out of the top hose, then put it in the top outlet until it comes out clear in the bottom outlet. Replace all of your hoses and thermostat. Then remove the bleed cap hose on the thermostat housing, and slowly fill the system up with a 50/50 mix of good quality antifreeze and water. When coolant starts coming out of the bleed point replace the bung hose and continue to fill up the header tank to the max level. Then turn on the engine and let it idle with the cap removed until the fans have come on and gone off. Leave to cool (could take a while!). Then replace the header tank cap and again turn on engine and leave to idle until fans have come on / gone off. Check for any leaks and if happy thats job done
Old Aug 9, 2004 | 03:25 PM
Spiky's Avatar
Spiky
understand every apart from the above???? or is that related to 4wd???
Old Aug 9, 2004 | 03:53 PM
wes's Avatar
wes
On a 2wd thermostat housing, there are 2 hose outlets, one goes to the turbo water feed, the other is capped with a rubber bung:
Old Aug 9, 2004 | 04:01 PM
Spiky's Avatar
Spiky
will check mine when i go home,
but i'm prettt sure i only have one
be back later
Old Aug 9, 2004 | 04:07 PM
3drstretch's Avatar
3drstretch
There is defiantly 2 spiky.You may need to remove cambelt cover to see it though.
Old Aug 9, 2004 | 04:48 PM
Spiky's Avatar
Spiky
i one have one
i just look on my car
Old Aug 9, 2004 | 08:23 PM
Guinnless's Avatar
Guinnless
Originally Posted by Spiky
i one have one
Mines only got one too (1989). It was only use on the three doors and early Saffs. The Cossie setup is self bleeding anyway if you leave the cap off a she warms up.
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
