Engine is Fooked
Old Jul 11, 2005 | 06:55 PM
essex_jamie's Avatar
essex_jamie
Default Engine is Fooked
well just had a phone call from my tunners grove garage, suppost to be having a new cam and lifters , and then they said u have major low oil pressure u need a bottom end rebuild and they said they wont rebuild a 1.6 its not worth it and they cant build a 1.9/1.6 rebuild as there booked for nearly a yar and dont have time for more re-builds, so they said they can get me a 2.1zvh running bout 250bhp from fiest frenzy for ฃ2500, im not sure wat to do.
Please can anyone advise me on wat to do either go 2.1zvh engine or get mine rebuilt by someone else or have a 1.9 bottom end wit a 1.6 head rebuild, wats best some rough prices would be good and wat would happen wit my old engine an all the part that are on it could they be re-used or wat
Current spec:
• Pace Intercooler
• -31 Actuator
• AB Engineering Custom Chip
• CVH 34 Spec AB Engineering Custom Cam
• Stage 1 Turbo .48 Exhaust Housing
• Cosworth Brake Conversion (Calipers, Grooved & Cross-Drilled Disks,)
• Koni Adjustable Dampeners
• AB Engineering Custom Springs
• Poly Bushed All Round (Dampeners, Engine Mounts, Exhaust Mounts)
• Adjustable Front Strut Brace (Blue)
• Steering Rack Raised By 2mm With Up Rated Bushes
• ABS Removed
• Full Mongoose Exhaust 3.5” Out Rolled **
• Shortened Cut Down Gear Stick
• Near fully blinged engine bay
Old Jul 11, 2005 | 07:15 PM
Rs1's Avatar
Rs1
Sounds a bit suss to me m8,rebuilding a 1.6 is not worth it?? Its up to the customer whether or not its worth it. Its strange how they dont have time for a rebuild,which tbh takes no time at all on a cvh but hey have the time to locate,sell and fit you a zvh
Old Jul 11, 2005 | 07:18 PM
essex_jamie
they got a 2.1zvh in there garage thye can use customer nver paid for it, im goin to phone some more places tommorrow anyone recommended any im going to phone engine advantages, jamsport and sheppards,
Old Jul 11, 2005 | 08:25 PM
Alvyn's Avatar
Alvyn
is/was the engine showing n e signs of low oil pressure ie knocking etc b4!
reason I ask is if NOT it's not a too big or expensive job to replace oil pump etc
Old Jul 11, 2005 | 08:51 PM
DazC's Avatar
DazC
Well to be honest, it's up to the customer to decide if it's worth rebuilding a 1600 or not!!! The 1600 cvh is not limited to the amount of power it can produce just because it's a 1600....
Old Jul 11, 2005 | 09:08 PM
essex_jamie
i have got mine currently running 201bhp at fly and wouldreally like that sort of specagain maybe bit more torque after ready bout ur car Dazc and the other series 1 wit rs7's on that stu done im ringing him in the morning, and Alvyn thye reakon its not the oil pump coz there was still oil pressure wen tested but it was very low so he said if the oil pump was fooked or the (cant remeber the name thing that gets stuck) was fooked it would show no oil pressure
Old Jul 11, 2005 | 09:16 PM
TurboFlush's Avatar
TurboFlush
if oil pump id eorn out it may decrease the pressure also. The bottom end just needs new bearings, thats all. you could actually do it yourself. not to hard.
Bring me the motor and I will help yah. . .
I live in Germany. LOL
TF
Old Jul 11, 2005 | 09:34 PM
DazC's Avatar
DazC
Originally Posted by escort_rs_turbo_series2
i have got mine currently running 201bhp at fly and wouldreally like that sort of specagain maybe bit more torque after ready bout ur car Dazc and the other series 1 wit rs7's on that Stu done im ringing him in the morning, and Alvyn thye reakon its not the oil pump coz there was still oil pressure wen tested but it was very low so he said if the oil pump was fooked or the (cant remeber the name thing that gets stuck) was fooked it would show no oil pressure
Andy's (the one on RS7 spokes) will be roughly 230bhp when completely set up.
Mine is a little bit special and has a lot done to it in preperation for a "modest" power increase! Stu at Motorsport Developments also built mine and are currently building my Dad's second engine. Stu and Kenny (Stu's business partner) won't sell you something you don't need and will advise yopu on your best course of action.
Old Jul 11, 2005 | 10:05 PM
essex_jamie
thnaks guys im def givin them a ring i really wanna stay 1.6cvh really its how the car was made so think it should stay like dat i am considering a 1.9 bottom end though for more strength
Posted: Mon Jul 11, 2005 9:25 pm Post subject:
i can really tell if it did before coz the cam was fooked so it sound like a scooby and dats was for two weeks didnt sound like there was any noises before cam went though
Old Jul 12, 2005 | 06:56 PM
DazC's Avatar
DazC
The 1900 is not any stronger than the 1600 mate.
Old Jul 12, 2005 | 08:38 PM
turbocabs's Avatar
turbocabs
these do all my engine work at romford still http://www.gosnays.co.uk/
Old Jul 12, 2005 | 09:39 PM
ajjames's Avatar
ajjames
the cam and followers would get knocked out in no time if you had low oil pressure so that is probably the cause of the cam noise also if you have low oil pressure the hydrolic followers wont open properly which make them noisey. you may just need the oil pump and when the followers have full oil pressure they might quieten down again could be wurth a try as the oil pump is easy to change
Ben26
Aug 27, 2015 08:56 PM
cameron2
Aug 10, 2015 12:14 PM
