how much boost?
Old Nov 12, 2003 | 04:35 PM
ADSRST's Avatar
ADSRST
Default how much boost?
how much boost can you push into standard 1.6 cvh turbo SAFELY ? is it about 18psi
Old Nov 12, 2003 | 04:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
Without any form of fuel mods?
No more than standard mate.
Old Nov 12, 2003 | 05:09 PM
ADSRST's Avatar
ADSRST
stu ive been running the set up that mark shead done for my 225 chip he done a couple of fuel mods ive got the grs cooler stg3 head plus other stuff, but my piston skirts have pushed in, i think they were cheap new ones they were +.5 and i had 1.5 mm skimmed off of the top . i was running about 20/22psi on boost, now i want to put in a standard block and pistons will it be safe to run about 18 psi .
cheers
Old Nov 14, 2003 | 11:19 AM
flashpoint's Avatar
flashpoint
Standard engine with out any care and attention to the bottom end build
I would only run 15 pi
Steve
Old Nov 18, 2003 | 10:25 AM
Rick's Avatar
Rick
1.5mm is too much of the piston. Boost is irrelevant, it's the power ur engine is producing.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
