co level
Old Jun 1, 2005 | 11:30 AM
cossied's Avatar
cossied
Default co level
a friend of mine has a 2 wd and cant get the co reading down. If the ECU screw has been over screwed can you tell by taking the cover off, if it proves to be ok what else should we check. It is running greens not sure which chip thanks
Old Jun 1, 2005 | 01:09 PM
rsnissan's Avatar
rsnissan
take the cover off. The screw is just plastic extention of an adjustable resistor on the ECU. You can take the cover off and see if the screw is worn out of if the actual resistor is knackered.
Old Jun 1, 2005 | 01:19 PM
cossied's Avatar
cossied
Default screw
thanks
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
IainRS1700T
Sep 25, 2015 06:44 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
little bram
Sep 21, 2015 02:50 PM
