Central locking problem on S2...
Old May 22, 2005 | 05:44 PM
turbotrev's Avatar
turbotrev
Default Central locking problem on S2...
I have just re-fitted and connected up me loom in my S2 RST after removing it from the car whilst it was being restored.
Everthing works except the central locking, if you lock the passenger door from inside manually (i have no door locks) both doors do lock, but if you try locking it manually from the drivers side it just locks then unlocks straight away.
The passenger side door actuator isnt making a noise but ive already tried another working door actuator and that made no difference.
Also when you arm/disarm the alarm it has no affect on the central locking.
It did all work before the car was stripped down, but since then I have removed all the tailgate electrics (cause I now have no wiper, lock, etc), front electric windows and mirrors, and all the old K-jet wiring (for cossie management).
Can anyone help as im running out of ideas
Paul
Old May 24, 2005 | 04:34 PM
rich2302's Avatar
rich2302
normally when it locks and then unlocks it's because it could not complete the circuit, is it possible that the fault is with the circuit to the boot as it is trying to lock something that isnt there ?
Old May 25, 2005 | 09:59 AM
davidnormanuk's Avatar
davidnormanuk
Check your earth in the passenger door. Thats where mine went which was doing the same thing.
Dave
Old May 26, 2005 | 12:15 AM
StuRST's Avatar
StuRST
i have a similar prob to this with mine, but its on the drivers door, is there an earth there as well?
Old May 26, 2005 | 08:14 AM
davidnormanuk
Yes. I found my earth wire had broken inside which is a common problem on these cars. Replaced the wire from the chassis behind the front speaker to the door and had no problems after that.
Dave
Old Jun 4, 2005 | 10:01 AM
cossieblood's Avatar
cossieblood
check your earth trev remember the last car
Old Jun 5, 2005 | 10:38 AM
james_birch's Avatar
james_birch
i have this but other way round! if i lock passenger side it unlocks its self stright after! i watched the drivers side lock thing and it didnt move when i lock from passenger side!
Old Jun 5, 2005 | 02:12 PM
turbotrev's Avatar
turbotrev
Cheers for all the help people.
Got it sorted now, one of the little metal pin connections in the multiplug to the door actuator had corroded and broken off (red multiplug, n/s/f footwell), replaced with new wiring and all is good.
Paul
stephenb4506
33
Oct 2, 2015 06:25 PM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
