ml developments oil breather on s2?
Old May 13, 2005 | 11:59 PM
rsadz's Avatar
rsadz
Default ml developments oil breather on s2?
just got my car back on the road after spendin too much on it again, fitted an ml developments breather but found that when it warmed up and came of the cold start it would cut out. so i plugged each end of the pipe that goes from the back of the breather to the metering head this solved the problem,but once out on the road it started to smoke badly coming off boost(white with oily smell) i put it down to the turbo and borrowed a m8s turbo which made no change! any ideas?.the bailey breather seems to be a very different set up! ive connected the vacuum feed to the inlet and the bottom feed to the back of the block, the other two obviously to either side of the rocker cover. it never smoked until i changed the breather i must be doing something wrong!! please help
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
