cosworth misfire
Old May 6, 2005 | 08:43 AM
cpcossie's Avatar
cpcossie
Default cosworth misfire
hello all any ideas on this one when my mates cossie boosts up it misfires we have changed the blue and brown sensors, phase sensor, crank sensor, leads cap and rotor arm. any help would be well helpfull
Old May 6, 2005 | 09:00 AM
cossied's Avatar
cossied
Default missfire
check the spark plug gaps if they are too big the boost can blow out the spark apparently, I think 28 thou is the recommended gap on higher boost. someone like PJ motorsport will confirm it. regards
Old May 6, 2005 | 03:54 PM
cpcossie's Avatar
cpcossie
spark plugs have been changed and are gaped correctly
Old May 6, 2005 | 11:46 PM
Dean Saff's Avatar
Dean Saff
What plugs are you using what gap did you set them too?
What spec is the engine what sort of boost are you running????
Old May 8, 2005 | 05:24 PM
Lillford 500's Avatar
Lillford 500
Is it a 2wd or a 4wd?
Old May 24, 2005 | 04:03 PM
cpcossie's Avatar
cpcossie
found the problem the crank sensor was too far away from the pulley now boosting up lovely cheers all.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
