FAO Alarm people / clifford avantguard 5 owners
jus had the above alarm fitted about 2 weeks ago, had a few problems at first setting the sensors but spot on after that.
trouble is now when i switch the engine off on the car the blue l.e.d flashes ten times, in the diagnostics code section of the owners book it says it means "power interupt" but that only refers to when the ignition is first switched on. the alarm is working fine but im a bit concerned about it. the guy who fitted the alarm is away for two weeks so cant ask him.
anyone any ideas?
anyone any ideas?
1 Post
could be wired up slightly wrong or pickin a switched feed wheer it should be a perm live or something, if fitted right they are fine - its just that they are much more envolved than most alarms., hence invite more gremlins.
its only jus started doing it after the car wasnt used for 4 days, the alarm is excellent well impressed with it but even the bloke who fitted it said there prone to niggly things going wrong because there advanced, as its not causing a problem ill wait until he gets back, just asking incase it was a sensor set wrong as there not the easiest thing to set and get right, cheers for the advice dude
Cos500
16-09-2015 09:50 PM
Adam Graham
06-09-2015 06:04 AM
