fuel pressure regulator on rs turbo
A mate has got a problem with his rs turbo fuel pressure regulator, basically when you plug it in it causes the car to cut out. runs perfect discounted.
Ive tried swapping fuel ecu over, and pressure regulator over as well, from my car and still does the same.
I read a thread ages ago about this problem, but cant rember what caused it!! any help much appreciated.
I agree, this is a common fault on these cars. I replaced the brown sensor on the back of the inlet manifold and not had a problem since.
Dave
Dave
The brown one is the thermo time switch and is nothing to do with the management system as it controls the cold start injector ONLY!
You need to replace the yellow sensor which is the coolant temp sensor for the management.
Matt Baxter
16-09-2015 08:30 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
Zoggon
10-08-2015 10:39 AM
