Just went for a drive and had a problem!!
Old Nov 7, 2003 | 09:09 PM
Jon777's Avatar
Jon777
Default Just went for a drive and had a problem!!
Just went out for a drive in the Saff and was crusing along with the stereo going and upto about 120,all was well.
Until the stereo shut off and the battery light came on,the rev counter stopped working properly and the temp gauge went to the bottom.When i got into a small village i stopped and had a quick look under the bonnet for anything loose and couldnt see anything,so got back in and went to start it,turned the key and no lights come on the dash at all but it fired up fine and i drove home as normal.
All the lights still work and it seems to have full power still.
Any ideas before i have a look tomorow??
Old Nov 7, 2003 | 09:16 PM
RANJ's Avatar
RANJ
id check the obvious, earth leads,fuses etc first
Old Nov 7, 2003 | 09:29 PM
Jon777's Avatar
Jon777
Yeah im thinking a fuse.
Old Nov 7, 2003 | 09:46 PM
XR4Timan's Avatar
XR4Timan
ITS DEFINATELY THE ALTERNATOR BELT (or poxy alternator) - car must've been dimming until the battery ran out
Old Nov 7, 2003 | 09:59 PM
Jon777's Avatar
Jon777
The battery didnt run out mate i done about 25 miles like it and the lights were all fine.The battery is brand new though.
Old Nov 11, 2003 | 04:35 AM
XR4Timan's Avatar
XR4Timan
Alternator on a Cossie comes with a built-in regulator which probably went balls-up - just check the belt, change alt and if u can change battery as well - all will be fine then.
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
gingeRS
Sep 4, 2015 06:29 PM
