cars just died!!!!!!!!
Old Apr 17, 2005 | 03:47 PM
rsmadandy's Avatar
rsmadandy
Default cars just died!!!!!!!!
hi there, i own an s2 turbo....was driving home before and the engine just cut out and wont start again.. ive changed the fuel pump relay and still cant hear no fuel pump priming....what else could have happened.
1) fuel pump dead ?
2) wiring?
3) fuse?
any advise would be great ie: where to look what to check.
thanks
andy
Old Apr 17, 2005 | 04:04 PM
cooler king's Avatar
cooler king
sorry to hear this mate, i dont have a clue but im sure oif you give it time, people on here may find the answer, just wondering, where abouts in manchester are you?
Old Apr 17, 2005 | 07:12 PM
rsmadandy's Avatar
rsmadandy
anyone
Old Apr 17, 2005 | 11:11 PM
davidreader5's Avatar
davidreader5
HI.
You list the most common, check you have battery voltage at the pump,
if not check fuse,next trace the wiring to and from the pump, just in case the
relay you tried may be faulty,, at the relay plug bridge pin 30 and 87 with a piece of wire,with the ignition on the pump will run contiuously if the wiring, fuse and pump are ok,
DAVE R
Old Apr 18, 2005 | 11:28 PM
rsmadandy's Avatar
rsmadandy
cheers for your help it was the earth under the car...new earth, bingo!!!.
Old Apr 19, 2005 | 09:46 AM
ken54231's Avatar
ken54231
Originally Posted by davidreader5
HI.
DAVE R
That piece of wire trick got me right outta stook when the pink relay stopped working years ago on holiday up north whilst visiting a zoo , lasted all holiday till i got home , kept fogeting to disconect it though
Might be the fuse , second row in middle area , 25 i think
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
bigup316
Aug 1, 2015 04:25 PM
