Help! Ford Sierra front wheel bearing pressed or not?
You may remember me i bought some mk5 escort bits off you etc.. Then for some reasion we had a bit of an issue over a jaguar s type you were selling when i turned up at address and car was sold?..
Anyways them bearings are race type you can knock them out with drift weather there cosworth hubs or std sierra both the same... when you fit new ones when u nip it up if it goes tight its the wrong bearing mind as the nut is suppose to be daft tight and stay free.. what make bearing you fitting?
Ah aye I remember you bought some bits off that mk5 cossie replica.. Spot on mate, the make of the bearings I think is napa summit like that.the measurements are 35,60,18.5mm. Cheers.
Ok well if you get stuck giz a message etc.. ive not used that brand of bearing before i use FAG or SKF myself never had a bother with them etc
adam151082
28-11-2014 08:13 AM
steerfromdarear
29-01-2014 08:26 PM
