Brake Upgrade MK1 focus
Old Aug 12, 2021 | 08:59 AM
Dendi's Avatar
Dendi
Question Brake Upgrade MK1 focus
Hi! I have a 2002 sedan MK1 focus (1.6 zetec SE) and just started to upgrade it, and the next step is my brakes!
My question is, can I fit ST170 brakes for sure on the front? Do I need to change anything on the front? Because I read that I need new hubs for example but the hubs are the same on the ST170 and on my 1.6 zetec focus (?)
I would appreciate if someone who already did conversations like that can help me!
Thank you for the help! Cheers (from Hungary [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img])
Old Aug 20, 2021 | 12:24 PM
The Black Count's Avatar
The Black Count
Hello, before doing any upgrades to the front brakes you will need to fit St170 hubs as the calliper is integrated to the hub on a standard focus but the st170 are bolt on. The rear brakes are likely to be drums, these can be removed and hubs fitted for disk brakes just 4 bolts each side but you will need custom flexible hoses as the drum brake lines go up the wheel arch where the disk brake lines go along the arms.
Old Aug 20, 2021 | 02:48 PM
XR2's Avatar
XR2
Depends. For the german market ANY MK1 Focus was fitted with rear disk brakes.
cossieant380
Jul 31, 2014 10:15 AM
Cauchi Jean Paul
Ford Focus (All Models)
Sep 27, 2011 10:43 PM
ellisjoseph66
Mar 29, 2011 10:46 PM
gazloveslou
Feb 21, 2009 08:57 PM
