Sierra front wheel hub carriers
Hi
Hope I don't upset any of you Ford enthusiasts. I have a kit car with Ford Sierra running gear (around 1983 era) fitted. The right hand side front axle carrier (where the track control ball joint and track rod end tapers are) is in a bad way. I can't locate a replacement 1983 carrier so was considering fitting the same item from a later vehicle. Does anybody know how the carrier changed dimensionally through the years?
Regards Phil
Regards Phil
steerfromdarear
29-01-2014 08:26 PM
