Zetec blacktop idle help
Old Apr 6, 2020 | 03:41 PM
Zelos2k's Avatar
Zelos2k
Default Zetec blacktop idle help
I have a 2.0 Blacktop running in my mk4 escort and have a couple of questions for you tech's.
1) The engine runs lovely but the idle is a little high, when you rev it it jumps up then settles. I'm running stock manifold and ECU.
2) Do I need to connect the VSS and the Clutch pedal switch ? Would this cause the idle problem ? Personally I dont think it would but would like some feedback. Does it actually have a VSS on the gearbox or is it read via the ABS sensor on these engines ?
Thanks in advance, hopefully someone can help me out.
Old Apr 6, 2020 | 05:33 PM
big_wasa's Avatar
big_wasa
What’s it idling at ?
Old Apr 6, 2020 | 05:55 PM
big_wasa's Avatar
big_wasa
Vss I run them with and without, I can’t tell a difference. The sensor is in the gearbox for both Focus and Mondeo. Reading I’ve done says it cuts fuel on over run. This is how they make pops and bangs maps by adding fuel on over run. ( and timing ).
From memory, clutch switch is a normally closed switch. So unconnected it will think the clutch is down and increase the rpm. Only a little. You can connect the pin to the sensor common earth ( brown )
if you you tell me if the loom / ecu is Focus or Mondeo I can tell you what pin is what.
Old Apr 6, 2020 | 06:27 PM
Zelos2k's Avatar
Zelos2k
Its from a 2000 Mondeo. I can check what ECU it is as well if you like. Thanks for the replies.
Probably idling at about 1000, sometimes it creeps up a little more.
Old Apr 6, 2020 | 07:53 PM
big_wasa's Avatar
big_wasa
2000 would be one of the last Mondeo zetecs.
I would guess the ecu is an OWL5.
To save cutting and pasting have a look here http://www.locostbuilders.co.uk/foru...php?tid=179921
Old Apr 6, 2020 | 08:12 PM
Zelos2k's Avatar
Zelos2k
just went and had a look and it's a BASH ecu. Engine number NGA XL063 I think although hard to read, could be NGB which is strange as it has the two part sump, water pump off set to the right and the black top cambelt covers and timing belt kit. Early black top ?
I might be wrong on the age as it was a long time ago I done the engine swap lol.
Old Apr 6, 2020 | 08:42 PM
Zelos2k's Avatar
Zelos2k
Thanks for your help, sorry to be a nuisance, which pin do I connect to where ? I see the OWLS ecu pinout you linked is that the same as a BASH ?
64 white -- Pin 39 c2513 clutch switch.???
Do I just run this to an earth or pin 38 on c2513 ? Cheers
Old Apr 8, 2020 | 06:53 AM
big_wasa's Avatar
big_wasa
91 brown, sensor common
carr955
Ford Mondeo Including ST
Jul 2, 2011 07:52 AM
Ferd
Aug 23, 2009 06:19 PM
nick27
Jun 18, 2005 10:41 PM
M Brian
Nov 13, 2004 02:54 PM
azcam
Jun 17, 2004 06:01 PM
