Escort MK4 ZETEC swap
Old Sep 30, 2019 | 06:36 AM
Kristjan000's Avatar
Kristjan000
Default Escort MK4 ZETEC swap
Hello.
Since i noticed that the 1.4 engine in my escort has started to tick and rattle (rod bearings) and i cant find another running 1.4 engine over here (and its slow as shit) then the zetec swap from a mondeo came into my mind.
Ive read that quite a few people have done this swap but i still have some questions.
1. Does the 2.0 96kw engine from mk2 mondeo fit straight in the engine compartment of an escort?
2. Which driveshafts and transmission do i have to use?
3. What do i have to modify/make myself in order for the engine to run?
All other info about this conversion is greatly appreciated.
Old Sep 30, 2019 | 03:22 PM
FloydH's Avatar
FloydH
Did the swap myself earlier this year, found this guide very helpful
https://passionford.com/forum/ford-e...onversion.html
Note : make sure you don't forget to cut the small piece out of the ledge by the top rear engine mount. I did & ruined the tensioner!
it's on page four about halfway down
Old Sep 30, 2019 | 03:33 PM
FloydH's Avatar
FloydH
...also just below there on the inner wing by where the water pump pulley's going to go, give it a big whack with a lump hammer! It's very close once it's all in mine's actually taken the paint off the inner wing with the small pulley bolts, when cornering left I guess
rwd xr2
Ford Mondeo Including ST
Jul 3, 2011 02:57 PM
131LL
Jun 16, 2010 07:06 PM
RS Juto
Jan 6, 2009 06:39 PM
lickshot
Jun 27, 2006 10:49 AM
