2wd cossie thermostat housing question
0-60 in 17 seconds (eek)
Inside my thermostat housing is a thermostat "held" in place by a spring-like piece of wire that locates inside a groove in the housing, but the thermostat is rattling about.
Now, is that normal, does it locate in place with water flow, or, should there be a rubber seal in there to positively hold the thermostat in place ?
If so, what is the sequence for re-fitting, seal, thermostat, spring, or, thermostat, seal then spring ?
Thanks in advance
Thanks in advance
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
Harryh24
26-08-2015 07:50 PM
