Connecting the aem wideband to l6 ecu
Anyone know what pins the analog input are on the l6 ecu positive and negative for my wideband output
Why would you want to connect an Oxygen sensor to a L6 ecu?
The L6 does not have an input for an Oxygen sensor and I doubt the hardware for it is present if you assume it's the same pin as in the L8..
Also the software that is used will not do anything with a signal from the Oxygen sensor.
Furthermore the standard Eprom is completely full with the standard program and there's no room for a Lambda control strategy.
Fiecos Dan
28-05-2006 11:08 AM
