Weird noise after fitting turbo actuator
Old Jun 8, 2019 | 06:47 PM
Andy77walker's Avatar
Andy77walker
Default Weird noise after fitting turbo actuator
Hi guy's,
my turbo failed a few weeks back so decided on a hybrid turbo, had that fitted at the garage. When I got it back the boost seems to back off at around 4000rpm.
So today I fitted a 7psi turbosmart actuator and now I'm getting a weird noise at around 3500rpm.
Does anyone have any idea what it could be?
It's a modified st250, stage 2 pumaspeed
Can't upload the video for some reason
https://youtu.be/ke1svKkZ7fU
Old Jun 8, 2019 | 11:48 PM
GVK.'s Avatar
GVK.
Hard to tell from vid but that sounds like a bad rattle!
I wouldn't be driving it....
Old Jun 9, 2019 | 09:45 AM
Mark Shead's Avatar
Mark Shead
You need to get it mapped if you have changed spec from map.
Mark
Old Jun 9, 2019 | 10:27 AM
Andy77walker
Thanks for the replies.
So I have backed off the nuts on the actuator arm and this has helped a little bit but still getting the same noise at around 4000rpm. Today I will undo the nuts and do them finger tight and see if that helps.
Any other ideas would be greatly appreciated. The turbo is a pumaspeed x37 hybrid 20% bigger than standard. I was told the map wouldn't be a problem, it would just not run at its full potential. It wasn't an issue with the standard actuator boost just seemed to level off after 4000rpm
Old Jun 9, 2019 | 12:29 PM
Mark Shead's Avatar
Mark Shead
You have changed the way the boost is controlled by putting a different pressure actuator on it so it needs a remap.
Mark
Old Jun 9, 2019 | 01:40 PM
Andy77walker
Thanks Mark
I will call my local tuning company in the morning and see what they say. To me it sounds like the actuator opening and closing really quickly, but we'll see.
I'll post an update when I know
Old Jun 19, 2019 | 10:12 PM
Andy77walker
Took my car to a company called hypertune today, Shane had a good look over it and found that the vacuum pipe on the actuator was on the turbo and vice versa. I think that's what he said.
Anyway took it out for a drive and it was a lot better at first but at higher revs it really started stuttering.
So Shane put it on the dyno and data logged with my stage 2 map, standard map and their own stage 3 map. He found it is under power on all maps, but on the tuned maps the fuel rail pressure drops a lot without throwing up an error code for some reason. Not sure why it's not doing it on the standard map tho
Old Jun 19, 2019 | 10:16 PM
Andy77walker
​​​​​​This shows fuel rail pressure on stock map and their stage 3 also power for all three maps
Old Jun 20, 2019 | 08:01 AM
Caddyshack's Avatar
Caddyshack
If you have a tuner looking at it then they should diagnose and fix, if they cannot then I would find a tuner who can. Mark Shead has responded on this thread and what he doesn't know ain't worth knowing. Do a quick google search and you will find his mobile and work details, see if he has the software to map this car. If not I would speak to MSD. Do not be afraid to travel to find the best.
Old Jun 23, 2019 | 10:20 AM
2Litre's Avatar
2Litre
As above - The tuner should have the answers. Do not be fobbed off and left with unanswered questions.
Tim
Richie15
Sep 29, 2014 05:58 PM
anvini
Aug 4, 2008 09:19 PM
Terry Tibbs
Fitness / Weight Training Discussions
Mar 22, 2007 01:01 PM
