cosworth radiator advise
Hey, I run a stock cosworth radiator in my xr4i. That one is broken now. And i am searching a good radiator so i can replace it.
The biggest problem is that my engine can run a bit hot on idle. When driving it is fine.
Also the car has an intercooler because it is going to be supercharged. The intercooler is modified and sits about 2" more to the front of the car.
The car has 2 Spal fans that blow 1233CFM each (2466CFM/4180m3/h total)
What is a good radiator that will cool good on idle and has good mounting points so the intercooler can sit on the same spot.
